Guest WiFi ACL
kirkland11
Beginner
Beginner
I'm trying to set up my Guest WiFi VAP on my Cisco WAP561 so that it only allows guest users to access the internet and none of the local services.  The network topography is simple;
Internet -> Netgear Cable Gateway/Router -> TPLink PoE Injector -> WAP561
I have a Guest VAP already made and captive portal set up, everything is working fine except for the fact that they can access everything on the network.  Once again, we would like to know how to set up an ACL to allow guest users to only access the internet.  We are using the cable gateway's DHCP server (10.1.10.1/24).  The WAP is set to a static IP of 10.1.10.10/24.  Please let me know of any other information you might need to help us with this, we've been trying to figure it out for a couple of weeks now with no success.
chinmoy.boruah1
Beginner
Beginner
Hope this link would help you out.
https://supportforums.cisco.com/discussion/11958491/wap-561-web-browsing-only
Chinmoy
Recognize Your Peers
