How do I activate WAP4410N and AP-1131AG?
chunhyungjoon
Hello, I'm new to Cisco devices.
I have WAP4410N and AP-1131AG for the school lab's Access point.
First, WAP4410N doesn't make connection to wired network.
There's no DHCP server in our school and uses below :
192.168.x.x ip address
255.255.0.0 Subnet
192.168.1.254 Gateway
210.220.16.7 DNS address.
So I seted these settings on the configuration page, but when I connect to the WAP4410N wireless, I can't connect to the internet.
Problem reporter in Windows 7says there's IP adress problem on the access point. ...but the ip address is correct.
I did everything on the manual ....
Second, AP-1131AG.
I entered with console cable and changed the ip address. And I enabled wireless radio(default:disabled) but I cannot find SSID with wlan.
I added SSID on SECURITY-SSID manager. It says 'interface on' on 802.11a/g, but it is the same. I can't find SSID. other labtops can't, too.
.... tried using vlan. FAILED....
Help me please! I need to set these APs till this weekend...
Thanks!
Hyung Joon Chung,
Thank you for the update. I have some new questions:
  1. Does the PC(s) have a static IP on the wireless network adapter as well as the wired?
  2. With a static IP address on the wireless network adapter, can you ping the gateway address 192.168.1.254?
  3. Can you also ping the WAP4410N address 192.168.102.200?
  4. Do you have wireless management enabled in the WAP4410N? If so, can you access the configuration pages after connecting wirelessly?
  5. Have you tried changing the IP address of the WAP4410N to 192.168.1.x?
5 Replies 5
mpyhala
Level 7
Level 7
Hyung Joon Chung,
Thank you for posting. You stated that there is no DHCP server on the network.
  1. Does this mean that the Windows 7 PC has a static IP address?
  2. What exactly is the IP address that you set in the WAP4410N?
Regarding the AP-1131AG: Please post your question at the following forum.
https://supportforums.cisco.com/community/netpro/wireless-mobility
Thanks for replying, mpyhala!
1. Yes, the PC has an ip address and it can connect to the school network with wired connection.
2. The ip address for WAP4410N : 192.168.102.200
                          for PCs : 192.168.102.x
I tried again after factory reset and made no changes but IPaddress, SSID.
....same result.
Ah, thanks for giving the URL for 1131AG!
Hyung Joon Chung,
Oh, is there no DHCP inside the WAP4410N? I didn't make any configurations on PC's wireless adapter IP!
I think that's why I couldn't use the AP. couldn't ping to 192.168.1.254 and 192.168.102.200. Also can't connect to conf. page.
I'll try this soon! Thanks, mpyhala!
Hyung Joon Chung,
Your welcome! Please let us know if this fixes the issue for you by marking this post as "Answered". If you need further assistance, we are happy to help.
