IPv6 for WRVS4400N
jewome62100
(Sorry for my English)
I buy a WRVS4400N router on amazon.fr because on cisco.com, the Product Specifications say "Dual-stack IPv4 and IPv6"
http://www.cisco.com/en/US/prod/collateral/routers/ps9923/ps9931/data_sheet_c78-496737.html
The ipv6 work for the local network. But the router does'nt fetch my IPv6 take by my ISP (by PPPoE)
How do I get IPv6?
3 Accepted Solutions
Aleksandra Dargiel
Hello Jerome,
My name is Aleksandra from EU-STAC team.
I would like to let you know that WRVS4400N does not support DHCP IPv6 client for WAN connectivity. It does only have DHCP v6 server for IPv6 clients on LAN.
The device which would meet your requirements is for example RV110W: http://www.cisco.com/en/US/prod/collateral/routers/ps10907/ps9923/data_sheet_c78-660141_ps9923_Products_Data_Sheet.html
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
To add just a little to what my colleague said, If you look in the Admin Guide for this router, it states that the Dual-Stack IP option is to use IPv4 on the internet and IPv6 on the local network.
There are some additional options for allowing 6to4 Tunneling. This allows your IPv6 network to connect to other IPv6 networks via tunnels through IPv4. The remote router also needs to support 6to4. Because the tunnel can be automatically formed based on traffic, there is no limit as to how many tunnels you can have.
I know that this is not the answer you were looking for, but the router that Aleksandra mentions is a good router for what you want to do.
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
Jerome,
Similar product with gigabit ethernet WAN port would be RV220W:
http://www.cisco.com/en/US/prod/collateral/routers/ps9923/ps11025/data_sheet_c78-630461.html
You may would like to have a look on emulator for this router:
http://www.cisco.com/web/sbtg/gui_mockups/RV220W_v1/home.htm
Aleksandra Dargiel
SBSC Europe
5 Replies 5
Aleksandra Dargiel
Hello Jerome,
Eric Moyers
CCNA, CCNA-Wireless
1-866-606-1866
jewome62100
Thanks a lot.
I return the product to my supplier.
I'm interessing by the RV110W,I had seen it before. But it didn't have Gigabytes ethernet ...
Do you have this product ?
Jerome,
Aleksandra Dargiel
SBSC Europe
thanks.
But the
RV220W -> 234€
RV110W -> 60€
+170€ Just for Gigabyte :S ...
Can I make a VPN in this router to one PC ou one iPhone alone ?
Because I don't need a VPN router to router
