LAP LED Cycle between Red and Green
gaborlaszlo
I just have Setup one WLC 2504 with LAP AIR-AP2702I-UXK9
Now i have the following symptoms:
Led do not stop Flashing between red and green.
The LAP have successfully joined the Controller and i am able to connect to the SSID to ,- and i  got the Right IP address assigned.
So it Looks everything fine.
Controller Logs Show also no strange Messages.
However the Led thingy disturb my Feelings Red means always something is wrong .  When i connect to the SSID the LED should turn to blue but it douse not.
It remains the Same.
Anyone have a Suggestion?
Thank You for Answers in Advance.
Milos Megis
Level 3
Level 3
you have universal AP (...UX...)
You need to prime it to your location (regulation domain)
You can do it with application "cisco air provision" on phone.
Now AP seems to be working but 5GHz interface should be down and 2.4GHz interface should transmit on lowest Tx power. So you need to prime AP.
Here is manual regarding priming of universal AP
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ux-ap/guide/uxap-mobapp-g.html
Just connect AP to controller.
Create WLAN with enabled option UNIVERSAL AP ADMIN (security: preshared key)
Turn on GPS on Phone where application is installed.
Connect to created SSID
and follow steps in application
