Need help to setup a 1602i Cisco aironet
ahmed-2015
Beginner
Beginner
I recently got an 1602i-K9 access point and I can not enter a configuration part :
 * I do not have the static address management so I cann't use web browser
 * When I plug my 1602 AP on a dhcp server, the bvi interface takes an IP address,  I cann't enter telnet and I cann't ping this IP adress
 * and when I use the console mode,I can acces the devise, get the enable mode but the command configure terminal does not work
Any help regarding the configuration of this device please ??
6 Replies 6
ahmed-2015
Beginner
Beginner
Always in the same subject,
Show version result : Version 15.2(4)JA1
Commande Configure terminal doesn't work, may I upgrade device ?
Thank you
Moin Ilyas
Enthusiast
Enthusiast
Could you please let us know if you would use it as Controller Based or Standalone Mode?
I am trying to use 1602i as standalone.
If you have it on Lightweight Image, follow the instructions to convert it to Standalone mode:
Lightweight to Autonomous Conversion
Once done, please refer to the following guide:
Cisco IOS Configuration Guide for Autonomous Aironet Access Points
I don't have a controller. The AP i Have is CAP not a SAP
Yes, you have Controller- based Image on it (CAP).
You'd have to change it to Standalone Image.
Please refer to the links, I've shared earlier.
Hope that helps.
Recognize Your Peers
