performance wap321
mattsaltzman
I would like to know how I can make sure I am getting the best performance out of my WAP321 access points. I have 3 in the ceiling on one floor and they are set to single point setup on all 3. is there a program I can use that will show me if my speeds are correct or is there a best practices for setting up the devices?
Moin Ilyas
Level 4
Level 4
Please refer to the following link:
https://supportforums.cisco.com/discussion/11967891/wap-321-best-practice
Also, a site survey would be helpful. Please refer to:
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/116057-site-survey-guidelines-wlan-00.html
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/68666-wireless-site-survey-faq.html
Hope that helps.
