Power for AIR-AP521G-A-K9
OL005801JIM
I have a customer who needs several of the standalone wireless AP's for three facilities.  Which power adapters do I need to make them work, absent a POE switch?  I'm assuming the part number options below all apply - just need to know which ones can be used off the existing switch and which ones need power within proximity of the AP location?
AIR-PWRINJ3=
AIR-PWR-A=
AIR-PWRINJ-FIB=
AIR-CONCAB1200=
Jim
wichilds
Level 4
Level 4
Jim
Thank you for your question.  This community is for Cisco Small Business products and your question is in reference to a Cisco Elite product.  Please post your question in the Cisco NetPro forums located here: http://forums.cisco.com/eforum/servlet/NetProf?page=main  This forum has subject matter experts on Cisco Elite products that may be able to answer your question.
Bill,
All the SKU's in my post were pasted in from the SBCS pricing tool, so I assumed this was the place to ask.  If you are certain I won't get the same answer from the group you're referring me to, I'll post it there, otherwise I'm hoping this is the correct community.
Jim
AIR-PWR-A
Pwr Sply In:100-240VAC Out:48VDC 380mA -1100,1130AG,1200,521
This is as per the Cisco COnfiguration tool.  I stepped through ordering one and it gave me the option of no power or this one.
