10-24-2012 07:05 PM
Thinking of getting a RV180W or RV220W for my home office. Setup E4200 before and other consumer models but first time to use business class (interested in VLAN support to keep home & office LAN separated for example).
So question with the firewall in these units ... is the SPI firewall already setup out-of-the-box? Anything else that I should be concerned about that is different from the security setup in the consumer models such as E4200?
Thanks for your advice.
Rob
Solved! Go to Solution.
10-24-2012 07:31 PM
Hi Rob, the firewall is set up by default. In this regard, there is not any modification required to 'add more', only take away some or customize if you needed specific services.
-Tom
Please rate helpful posts
10-24-2012 07:31 PM
-Tom
10-25-2012 06:33 PM
Thank you Thomas. I'm looking forward to taking it for a spin.
Rob
