SG300-10 Dead ?
xtnetwork.sarl
We tried to update our Cisco SG300-10 to latest version 1.4.8.06, since then the system is completely dead, after the upload in HTTP/HTTPS mode the switch turned off all Ethernet ports (without rebooting) rendering the web console innoperent. After a hard reboot the switch became up (System LED green and not blinking) but still, no Ethernet ports working (no LED, nothing), we then tried a hard reset (20 seconds on the reset button), and now the system is not booting anymore (System LED in an endless blinking status).
We tried a USB to Serial DB9 cable to check if there is something on the CLI console (with the good baud rate): nothing, blank screen.
Can we consider our switch as dead ? Is there something we can do ?
Thank's
Iliya Gatsev
Hi, My name is Iliya Gatsev from Cisco Technical Support Team.
Please open a case with Cisco Technical Support. Here is the contact of the technical support :
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco TAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
Jorge Obregon
I hope you are doing well.
In order to determine if this is a hardware issue or not I would advise you to do the following.
  1. Do the 30-30-30 factory reset
    1. With the device turned on press and hold the reset button for 30 seconds
    2. Then Unplug the switch from the power still holding the reset button for 30 seconds
    3. Then Plug the power back in still holding the reset button for the last 30 seconds
  2. Once the switch boots up connect a PC to port 1 and set up the static IP on the PC 192.168.1.10 255.255.0
  3. Try to ping to the default switch IP address 192.168.1.254
If successfully please proceed to do the firmware upgrade/re-flash using the software “tftpd64 or tftpd32”
            ** please see image attached for the tftpd32 settings
If not please give us a call to 1866-606-1866 so we can move forward
