static IP for wifi devices for wap125
TomPP04855530
i ve just bought cisco wap 125 AP.
Is there an option to set ip range for devices which need to be connected to ssid.
every new device gets 169.254.x.x/16 ip adress. i want make 192.168.2.x/24
kind regards, Tom
marce1000
 - I presume you should be able to change the DHCP-pool parameters through the management interface of the WAP.
 M.
hi, i can change dhcp to static, but it works for lan only.
WiFi client still gets "router-own" ip adresses which is really sad, because its simple and basic functionality even for cheap, old routers and ap.
