WAP121-A-K9 V01 firmware will not upgrade
Todd Beason
I have 2 WAP121-A-K9 WAPs with firmware 1.0.2.3 that I want to upgrade to 1.0.6.2.  The first WAP upgraded without a problem.  The second will not upgrade, I get the error message: Firmware upgrade has failed.  Please ensure that valid entries are specified in the required fields.
I know the firmware file is fine since it works on the first WAP.  I have reset the second WAP to factory setting and tried and it fails with the same error.  I also tried firmware 1.0.4.4 and it fails.  Any ideas how to get this to upgrade?
Todd Beason
The WAP was using POE for power.  When the power adapter was used the WAP successfully upgraded to the latest firmware.
