Wap121 SSID for DHCP & Web only
guy.monet
Hi, I want to know how to configure ACL to have access to dhcp and web only.
My router does not support tag vlan.
Any suggestion ??
Guy
Bilal Nawaz
You need an extended ACL as below:
AP#ip access-list extended Allow_DHCP_WEB
AP#permit tcp any any eq www
AP#permit tcp any any eq 443
AP#permit udp any any eq bootpc
AP#permit udp any any eq bootps
AP#deny ip any any
AP#exit
(Assuming you want to enable this on the WAP inbound to filter for client laptops?)
AP#interface Dot11Radio 0
AP#ip access-group Allow_DHCP_WEB in
If you want to block outbound traffic use the bootpc and bootps ones along with
Permit tcp any any established
If not, just apply to the correct interface.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Bilal Nawaz
AP#deny ip any any
AP#exit
Hope this helps
