WAP321 captive portal, passwords can't contain special characters
FrancoisMalard
Best practices include :
passwords must contain A..Za..z1..9 + special characters (+=-&;! etc )
Using local database or Radius, same filter in WAP321 (Firmware Version:                    1.0.4.2 ) :
special characters are forbidden by Captive portal !!
Need to be modified.
Best Regards
lariasqu
Hi Eduardo, thank you for using our forum, my name is Luis I am part of the Small business Support community. Thank you for your feedback as well, as part of my functions as monitor is redirect or pass the information to the correct department, in this case I will send this information to development so if you want you can reach out to our Small Business Support Center and open a Service Request in order to verify the specific issues details. You can find the appropriate contact information for SBSC in the below link.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Greetings,
Luis Arias.
Cisco Network Support Engineer.
