WAP321 configuration
crathjen2
We have recently purchased a WAP321 Wireless access point and I am having an issue setting it up. I'm trying to set up a separate VAP and VLAN that is separate from the management VLAN of "0". I have assigned it an SSID and gave it a VLAN ID of 33. I could see the SSID listed in the wireless networks, but I cannot connect to it. How do I go about setting this VLAN ID network up and accessing the internet? It is plugged into a random port on our switch. I have set this up as VAP1. What we want the final outcome to look like is setting up a guest wireless and an internal wireless on the same device. Right now I am concentrating on the guest wireless.
If somebody could assist, that would be helpful.
Moin Ilyas
Level 4
Level 4
Please refer to the following link:
http://www.cisco.com/c/dam/en/us/td/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
