WAP361 Firmware update
I have 5 WAP361 running and I'm happy with your product.
4 out of 5 could be upgraded to firware 1.1.4.0 without any problem.
The remining one stays at 1.1.2.4. I tried several times without success.
I tried to upgrade to 1.1.3.2, but also without success.
Do you have a suggestion, what to do upgrade to 1.1.4.0?
Thanks for your help.
Thomas
pieterh
you need to provide some more information
what was the old firmware version of the other wap's?
>>>> whithout success <<<  => what do you mean, what error do you get ? can you produce some logging on the process ?
zuesxaini
instapro v10.45
Thomas
Ensure that you are using the correct firmware file for the upgrade. Download the firmware file for version 1.1.4.0 directly from the official manufacturer's website or support portal to make sure it's the authentic and compatible version.
