WAP371 - Limit Bandwidth for Particular Users
southerndoc
With the Ubiquiti WAP's, I have the ability to create user groups that can restrict bandwidth.  I can then assign a user to one of those groups.  For instance, if someone is hogging up bandwidth, I can limit them to 5 Mbps downstream and 1 Mbps upstream instead of the default 250 down/30 up.
Is there a way to do this with the WAP371 series?
dwarakbesant1
To apply bandwidth restriction, follow the steps given below.
Step 1: Create a Host
Go to Objects > Hosts > IP Host and click Add to create an IP Host with the following parameters.
Parameter
Value
Description
Name
Sales
Name to identify the Host. Duplicate names are not allowed.
Type
Network
Select the type of host.
Available options:
-       Single IP Address
-       Network IP Address with subnet
-       IP Range
-       IP List to add assorted IP
    Addresses
IP Address
192.168.168.0
Specify IP Address based on the Host Type selected.
Host Group
Host Group
Select host group i.e. host group membership. Single host can be member of multiple host groups.
Click OK to create the IP Host.
Step 2: Create QoS Policy
Go to QoS > Policy > Policy and click Add to create a policy with the following parameters.
Parameter
Value
Description
Name
Sales_Policy
Name to identify the Policy. Duplicate names are not allowed.
Policy Based On
Firewall Rule
Select any one option to specify for whom the policy is to be created.
Policy Type
Committed
Select any one option to specify policy type
Available Options:
Strict - In this type of policy, user cannot exceed the defined bandwidth limit.
Committed - In this type of policy, user is allocated the guaranteed amount of bandwidth and can draw bandwidth up to the defined burst-able limit, if available.
Implementation On
Individual(Upload/Download)
Select any one option to specify implementation strategy of policy.
Available options:
-       Total(Upload + Download)
-       Individual(Upload/Download)
Priority
1 – [Business Critical]
Set the bandwidth priority. Priority can be set from 0 (highest) to 7 (lowest) depending on the traffic required to be shaped.
Guaranteed – Burstable Upload and Download
64 - 128
Set the guaranteed and burstable bandwidth.
Bandwidth Usage Type
Shared
Select any one to specify the bandwidth usage.
Available options:
Individual – Allocated bandwidth is for the particular user only
Shared – Allocated bandwidth is shared among all the users who have been assigned this policy
Click OK to create the QoS Policy.
Step 3: Create Firewall Rule to apply QoS Policy
Go to Firewall > Rule > IPv4 Rule and Add a firewall rule to apply the QoS Policy created in Step 2.
Click OK to create the Firewall Rule.
The above configuration applies bandwidth restriction on the Host Sales.Oracle training in chennai | Java training in chennai
