WAP4410N and some WMM problem
zhushazang
We aquired a WAP4410N and have problems with users that use Windows Vista®.
They aquire ip in dhcp mode, but don't navigate.
Some Vista clients are normal, some not. I noted that i clear all wireless connection then try connect the system ask about a PIN. Ok, if i put the PIN, everything is all right. But, in the same way, some Vista clients don't ask PIN and don't navigate. Some one know how i can force this clients ask to a PIN?
Thanks for now.
0 Replies 0
