WAP4410N bridge settings - best performance?
kriegtiger
I ordered a pair of WAP4410N to use as a bridge for a split office. So far they have worked without a hitch but the throughput is less than stellar and I was wondering what the recommended configuration was for best performance (and how much speed could be expected in general) out of these two?
The setup:
2 WAP4410N devices connected to cisco SF300 series POE managed switches, on 100mb PoE port for data and power
static IP's for both
Wireless mode set to B/G/N mixed on a channel where other AP's don't reside
security as wpa2-personal with a 16 character complex password
AP mode is 'bridged' and each node has the other's MAC
Firmware:
PID VID:     WAP4410N-A V02
Software Version:     2.0.4.2
The two nodes are separated by about 25 yards across a parking lot with direct LoS to the other, placed inside a window mounted on the wall - elevated at about 10' so cars in the lot outside do not block visibility. At best the throughput I've seen is 1megabyte/sec, and that seems very slow/clunky to me for the 802.11n specification. Am I missing some setting, updated firmware, or physical setup (AC power instead of PoE for better antenna output maybe?) to have such limited performance?
Thanks in advance.
Updated firmware after posting from 2.0.2.1 - Tib
7 Replies 7
rmanthey
Level 4
Level 4
