WAP551 WAP561 AC Power Adapter
Hi there,
Can you please help me determine if the WAP551 & WAP561  AP can be powered by an AC adapter.
I am not able to find the information on their datasheet and quick install guides.
This is leading me to believe that they are only PoE powered.
I also tried looking for a picture of the ports of this AP but I failed to find any.
Thanks a lot for the help.
Jake Stroud
It requires PoE.  An injector should work fine.
The answer here is. Both the WAP551 and WAP561 are PoE ONLY powered APs.
So there is no option for an AC adapter.
Check Table 2. Overview of Cisco Small Business Wireless Access Point: Feature Comparison
of the link below
http://www.cisco.com/c/dam/en/us/products/collateral/wireless/small-business-100-series-wireless-access-points/c45-697410_qsg.pdf
