WDS between different devices.
Hello!
I am going to setup some accesspoints for a client.
Currently they have two AP541N running in a cluster.
I want to add a WAP571E and a WAP371.
From what I've read they can't join the same cluster which means I have to use the WDS Bridge function.
What I'm simply wondering, will it work? I don't want to order hardware that I can't get running together smoothly.
Thanks in advance!
Ingrid Aragon
Kristoffer, I am one of the engineers from the Small Business team.
If you plan to add the 3 APs in a cluster, that won't work. The golden rule to form a cluster is the same WAP model and the same firmware version.
A cluster can be formed between two APs if the following conditions are met:
- The APs use the same radio mode (for example, radio 1 uses 802.11g)
- The APs are connected on the same bridged segment.
- The APs joining the cluster have the same Cluster Name.
- Clustering mode is enabled on both APs.
I hope you find this helpful.
You'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
Thanks for the reply, I had already understood that forming a cluster with the two old AP541N accesspoints wasn't possible.
The amount of accesspoints I want to equip:
AP541N
AP541N
WAP371
WAP571
(worth mentioning is that they'll all be connected to the same switch)
So that users may roam around freely with a smooth operation on their devices.
Can I use the WDS Bridge function with all four accesspoints?
Yes, you can use the WDS Bridge, but keep in mind that:
- You will lose 50% of your bandwidth.
- All the units will be independently configured.
- All units need to reach to the master AP.
Click here for more information about WDS Bridge.
Ah thank you for your answer.
Much appreciated!
