Wireless disconnects
Genome_666
Beginner
Beginner
Hi Guys
I am at my wits end here with my wireless implementation and hoping somebody can help.
I have 8 WRVS4400N Wireless-N routers set up on different channels using the same SSID and WPA2 enterprise authentication for roaming. Everything seems to connect fine and works for PC's, phones etc but for some reason the MACs I have here keep dropping the connection even though it shows it is still connected. I have narrowed it down to mac as no other deviced have an issue. To get them connected I just turn off airport then turn it back on.
I put in a Dlink router with WPA2 enterprise auth (same settings as the Cisco except it is using 802.11g) and there seems to be no issues. Even if I change the Cisco APs to use 802.11g I still have this issue.
Is there any setting that I am over looking here that allows compatability for mac?
I have tried everything I can think of, even updating the firmware of the routers ( V2.0.2.1-ETSI).
Here are the settings I am using on one of the APs, the others are the same except for the channels.
Wireless network mode: G/N mixed
wireless channel : 11
Multiple BSSID enabled (using 2 SSIDs, one using Radius and one WPA2 PSK for testing)
Security
Wireless isolation: disabled
Sec mode: WPA2 enterprise
Wireless Isolation (within SSID): disabled
Key renewal: 3600
Advanced Settings
Channel BW: 20MHz
Guard Int: 400ns
CTS protection mode: Auto
Beacon int: 100
DTIM int: 1
RTS threshold: 2346
cindy toy
Rising star
Rising star
Hi Darren,
I suggest that you call the Small Business Support Center.   Please go here to find the phone number in your country:
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
Regards, Cindy If my response answered your question, please mark the response as answered. Thank you!
Amjad Abdullah
Engager
Engager
I think the problem will be related to the Mac's overall. I've seen many compatibility issues between Macs and Cisco.
Rating useful replies is more useful than saying "Thank you"
Yeah I came to the same conclusion. Still haven't come right. I even did what Cindy said and contaced the support but still nothing. This is why I really hate Mac.
Recognize Your Peers
