WRT600n DHCP server
storf
I'm using a Cisco WRT600N (1.01.36 build 4) and cannot figure out how to keep the DHCP server disabled. There's another DHCP server on my network, and the WRT600n messes things up all the time. Disabling the feature on the WRT600n, then rebooting keeps it off for at most a day or so, but then it re-enables itself while the GUI shows it as disabled.
This is unexpected behavior and should not happen with a mature firmware release.
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
The WRT600N is one of our Consumer Routers. You should look here for help with that device.
http://homesupport.cisco.com/en-us/wireless/lbc/WRT600N/
If this had been on of our devices, I would first suggest making sure that the FW is up to date. Then doing a factory reset and manually reconfiguring the device. If that does not work, I would call the Consumer Support line 1-800-326-7114
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
