Hi Community
I am new to the forum but really desparate.
My first Cisco product and trouble trouble trouble.
I bought a WRVS4400N with the actual Firmware V2.008.ETSI
I am connected to the Internet by cable, cablemodem is plugged into my new Cisco router then goes to a Gigabit Switch (3Com), House ist equipped with cat. 7 Gigabit cable.
My Problem:
Modem and router up an running on a 7/24 hour basis.
Problem 1:
I am using Wlan functionality but every other day, the Wlan loses internet connectivity meaning I have contact to LAN bot WAN (internet) is dead, all W7 clients show me the "!" in the internet connection. If I switch to cable (gigabit) connection, everything works fine. Log into the router (via LaN), do a reset of the router and everything (cable and Wlan) is up an running again.
Problem 2:
Sometimes (not often) also cable shows the "!", no log in to the router is possible, have to reset the router and up an running again.
I am very confused, I switched the cable modem (from a 100mb to a gigabit lan) but the problem persists.
As Wlan and Lan can be affected, I think there must be a problem with the router, I am using the standard setup with a hidden wlan name, changed the wlan connection types from all to G only no luck.
It seems that the router "loses" connectivity to internet on purpose.
Can someone give me a tip?
If you need more specification feel free to ask.
Thank you very much for your time.
Best
Andreas
