1100 AP SSID Broadcast
Chuan Liu
How can I enable SSID broadcast for a non-guest mode in Cisco 1100 AP? In the GUI interface, the broadcast selection seems always associated with the guest SSID; in CLI, I can not find the command.
Any advice is appreciated.
Thanks.
gamccall
Level 4
Level 4
Guest-mode is the command to do what you're trying to do, and that's all it does. The guest-mode command doesn't do anything except turn SSID broadcast on or off. It doesn't change any security features.
Possibly a confusing choice of terminology on Cisco's part, but not a harmful one.
Thanks.
The rating system is not working. I rated 5 for this answer that solved my problem, but it does not show in the conversation page.
