1130AG AP Issue
I have serveral 1130AG AP that when they are configured to use LWAPP all of my Motorola Handheld scanners connect to the SSIDs fine.
When I have some that are on Autonomous then the scanners will not connect at all.
I have upgraded a test 1130AG to the lates IOS and that does not help.
Any suggestions.
12 Replies 12
Scott Fella
Not enough information to help you here... You need to post your configuration for the autonomous AP and tell us what SSID the devices are using to connect.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
This is my config, neither SSID will connect via the scanners, but my phone will connect to either.
version 12.4
no service pad
service password-encryption
hostname TESTWAP
enable secret 5 $1$7Sa0$E/ht0mNM7EYOo9ORkeCc2/
no aaa new-model
dot11 syslog
dot11 ssid GUESTTEST
   vlan 8
   authentication open
   guest-mode
dot11 ssid PRIVATE
   vlan 1
   authentication open
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 A586DEC9AA12D1772BF8CF617842
encryption key 2 size 128bit 7 4586DEC9AA12D1772BF8CF617842 transmit-key
encryption key 3 size 128bit 7 93CEC7D386E2F7EB4AAC8D3D58E7
encryption key 4 size 128bit 7 990EC692BCBABCEA6A2ACBA5586E
ssid GUESTTEST
ssid PRIVATE
station-role root
rts threshold 2312
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.8
encapsulation dot1Q 8
no ip route-cache
bridge-group 8
bridge-group 8 subscriber-loop-control
bridge-group 8 block-unknown-source
no bridge-group 8 source-learning
no bridge-group 8 unicast-flooding
bridge-group 8 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
ssid GUESTTEST
ssid PRIVATE
dfs band 3 block
channel dfs
station-role root
interface Dot11Radio1.1
no ip route-cache
bridge-group 1
interface Dot11Radio1.8
no ip route-cache
bridge-group 8
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.8
no ip route-cache
bridge-group 8
interface BVI1
ip address 192.168.100.36 255.255.255.0
no ip route-cache
ip default-gateway 192.168.100.254
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
line vty 5 15
login
end
so if you are using wep
you have to add the following commands under dot11radio configuration mode
encryption vlan 1 mode wep mandatory
encryption vlan 8 mode wep mandatory
encryption vlan 1 key .....
encryption vlan 8 key ..............
if you don't want to use wep , then there is no need to have:
please make sure to rate correct answers
Not using WEP. Still no luck.
What are you using? What is setup on the WLC that works? On the WLC post the show WLAN
This way we can see how the SSID is configured since you mentioned that the devices connect fine to those APs.
-Scott
This is the WLAN config on the WLC that I need to use.
WLAN Identifier.................................. 4
Profile Name..................................... WIFIGUEST
Network Name (SSID).............................. PRIVATE
Status........................................... Enabled
MAC Filtering.................................... Disabled
Broadcast SSID................................... Enabled
AAA Policy Override.............................. Disabled
Network Admission Control
  Client Profiling Status ....................... Disabled
  Radius-NAC State............................... Disabled
  SNMP-NAC State................................. Disabled
  Quarantine VLAN................................ 0
Maximum number of Associated Clients............. 0
Maximum number of Clients per AP Radio........... 200
Number of Active Clients......................... 38
Exclusionlist Timeout............................ 60 seconds
Session Timeout.................................. 1800 seconds
CHD per WLAN..................................... Enabled
Webauth DHCP exclusion........................... Disabled
Interface........................................ wifi
--More-- or (q)uit
Multicast Interface.............................. Not Configured
WLAN IPv4 ACL.................................... unconfigured
WLAN IPv6 ACL.................................... unconfigured
DHCP Server...................................... Default
DHCP Address Assignment Required................. Disabled
Static IP client tunneling....................... Disabled
Quality of Service............................... Silver
Scan Defer Priority.............................. 4,5,6
Scan Defer Time.................................. 100 milliseconds
WMM.............................................. Allowed
WMM UAPSD Compliant Client Support............... Disabled
Media Stream Multicast-direct.................... Disabled
CCX - AironetIe Support.......................... Enabled
CCX - Gratuitous ProbeResponse (GPR)............. Disabled
CCX - Diagnostics Channel Capability............. Disabled
Dot11-Phone Mode (7920).......................... Disabled
Wired Protocol................................... None
Passive Client Feature........................... Disabled
Peer-to-Peer Blocking Action..................... Disabled
Radio Policy..................................... All
DTIM period for 802.11a radio.................... 1
DTIM period for 802.11b radio.................... 1
Radius Servers
--More-- or (q)uit
   Authentication................................ Global Servers
   Accounting.................................... Global Servers
      Interim Update............................. Disabled
   Dynamic Interface............................. Disabled
Local EAP Authentication......................... Disabled
Security
   802.11 Authentication:........................ Open System
   FT Support.................................... Disabled
   Static WEP Keys............................... Disabled
   802.1X........................................ Disabled
   Wi-Fi Protected Access (WPA/WPA2)............. Disabled
   Wi-Fi Direct policy configured................ Disabled
   EAP-Passthrough............................... Disabled
   CKIP ......................................... Disabled
   Web Based Authentication...................... Disabled
   Web-Passthrough............................... Disabled
   Conditional Web Redirect...................... Disabled
   Splash-Page Web Redirect...................... Disabled
   Auto Anchor................................... Disabled
   FlexConnect Local Switching................... Disabled
   FlexConnect Local Authentication.............. Disabled
   FlexConnect Learn IP Address.................. Enabled
--More-- or (q)uit
   Client MFP.................................... Optional but inactive (WPA2 not configured)
   Tkip MIC Countermeasure Hold-down Timer....... 60
Call Snooping.................................... Disabled
Roamed Call Re-Anchor Policy..................... Disabled
SIP CAC Fail Send-486-Busy Policy................ Enabled
SIP CAC Fail Send Dis-Association Policy......... Disabled
KTS based CAC Policy............................. Disabled
Band Select...................................... Disabled
Load Balancing................................... Disabled
Multicast Buffer................................. Disabled
Mobility Anchor List
WLAN ID     IP Address            Status
802.11u........................................ Disabled
  Access Network type............................ Not configured
  Network Authentication type.................... Not configured
  Internet service............................... Disabled
  HESSID......................................... 00:00:00:00:00:00
Hotspot 2.0.................................... Disabled
from the WLAN config, that is an open WLAN.  If that is the case then:
conf t
int dot0
no encryption key 1 size 128bit 7 A586DEC9AA12D1772BF8CF617842
no encryption key 2 size 128bit 7 4586DEC9AA12D1772BF8CF617842 transmit-key
no encryption key 3 size 128bit 7 93CEC7D386E2F7EB4AAC8D3D58E7
no encryption key 4 size 128bit 7 990EC692BCBABCEA6A2ACBA5586E
end
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Scott Fella
Add guest-mode on the PRIVATE SSID. That is how it's configured on the WLC.
-Scott
I have set the No command for the encryption and set the PRIVATE ssid to guest-mode with no luck. My scanners see the access point radio mac address, but will not connect.
that should work, teh WLAN from the WLC isn't running any encryption.  with removing those commands should do the same on the aIOS as well.
HTH,
Steve
HTH,
Steve
I reset the AP to factory default and setup:
one SSID  - no go.
one SSID with 1 VLAN - no go
This is frustrating.
Try with OPEN authentication and broadcasting SSID.
