1130AG Repeater issue
Dan Martin
Beginner
Beginner
When I set the AP as an access point the radio is green and working.  When I set the Infrastructure SSID to the only SSID I have configured then change the Network Interface for the radio to Repeater as well as put the Root Parent Wireless MAC address in the Root Parent MAC 1 field the radio is down.  I cannot get it back to green.  Any suggestions?
Thanks in advance,
Dan
8 Replies 8
Stephen Rodriguez
Can you post the config of the patent and the repeater?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
Hello
Attached is the config.txt.  I'm not sure where the patent file is, but will keep looking.
sorry, that was supposed to be parent.
HTH,
Steve
I appologize.  I have spent the better part of the day trying to open the .bin file to get the config data.  Still working on it.
...and I have taken screen images of all the wireless settings.  If there are specific setting you want to see please let me know.
OK, to make it easier I renamed the config files to more appropraitely reflect how they were created.
Thanks again,
Dan
ok, the SSID doesnt' match what you have configured on the 'parent' device.  For the repeater to work, they have to match.
the config should look similar to :
dot11 ssid dpm1028
   authentication open
   authentication key-management wpa
   guest-mode
   wpa-psk ascii 7 0602192C484404495D4547
   infrastructure-ssid optional
username Cisco privilege 15 password 7 08255A430D1308
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid dpm1028
antenna gain 128
parent 1 001d.7318.fe6e
parent timeout 10
station-role repeater
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled dot11 ssid dpm1028
   authentication open
   guest-mode
bridge irb
no ip address
no ip route-cache
ssid dpm1028
antenna gain 128
parent timeout 10
bridge-group 1
Out of curiosity.  Are you able to plug the 1130 into the LAN and just run it as an AP instead of being a repeater?
Steve
HTH,
Steve
I took the config verbatum and seemed to lose complete access to the AP.  So I restored from factory and tried to get to the same place with the settings.  I got confused with the interface blocks.  There are 3, it seems yours are almost identical.  Is that where I am wrong.  I can use this as an AP but then it sits where my root AP is.  I am not sure what I gain from that.  Unless I run an ethernet and make it an AP elswhere.  Am I missing something?
Thanks Dan
version 12.4
no service pad
service password-encryption
hostname ap
enable secret 5 $1$8OuO$tKs4fSgbfusCSIszC5lWz0
no aaa new-model
dot11 syslog
dot11 ssid dpm1028
   authentication open
   mbssid guest-mode
   wpa-psk ascii 7 020212560F0C0271141C5C
username Cisco password 7 02250D480809
bridge irb
no ip address
no ip route-cache
broadcast-key change 3600
ssid dpm1028
antenna gain 28
speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
mobile station scan 2437
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.10.92.81 255.255.255.0
no ip route-cache
ip default-gateway 10.10.92.1
ip http server
no ip http secure-server
ip http help-path
http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
version 12.4
no service pad
hostname ap
no aaa new-model
dot11 syslog
dot11 ssid dpm1028
   authentication open
   mbssid guest-mode
bridge irb
no ip address
no ip route-cache
ssid dpm1028
antenna gain 28
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
no ip route-cache
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
end
