02-28-2012 08:18 AM - edited 07-03-2021 09:40 PM
I can configure two APs as a bridge with one as an AP with RMW enabled, and the other in WGB mode. I have three VLAN, each configured on both APs with their own SSID. Each switch (cisco switches) port is in trucking with only the three vlan allowed. The APs are associating with each other but not passing VLAN traffic. What am i missing????
Solved! Go to Solution.
02-28-2012 04:24 PM
Kevin,
As far as I know, 1131s do not support root/non-root bridging, only root/WGB for access, which is different. This is probably why you're having trouble. The 1240s do support root/non-root bridging.
Justin
02-28-2012 01:32 PM
The WGB only can pass the vlan it is associated to. If you wanted to pass multiple vlans, then you need to setup a bridge between the two... One root and the other non-root.
02-28-2012 01:40 PM
Thanks Scoot, But that is kind of what I thought I was going. Any ideals on how to accomplish this? I thought the AP was the root and the WGB was the non-root.
02-28-2012 02:54 PM
Well yeah... but a WGB can only pass one vlan and that vlan is the vlan it associates to on the root ap. If you need to pass multiple vlans, then you need bridge to bridge and then hang an ap off that non-root bridge.
02-28-2012 03:30 PM
Thank again Scott for your time and help. I am have a hard time configuing a non-root bridge, it is not an option in the GUI or the CLI. My APs are AIR-AP1131AG-A-K9 with software ver 12.3(8)JEA2.
02-28-2012 04:07 PM
Take a look at this
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_example09186a00805b9b87.shtml
Scott Fella
Sent from my iPhone
02-28-2012 04:32 PM
Thanks Scott, that is the doc I have been using, and has gotten me this far.
02-28-2012 04:24 PM
Kevin,
Justin
02-28-2012 04:39 PM
Justin, Thank you, I belive leave you are right, but in this cisco doc
it states that WGBs do support VLANs when in infrasturcture mode. So I thought it would work. But I have trid that with no luck, so I am thinking you are 100% correct.
Thanks for the help,
If I could get a 1240 could I configure it in non-root mode and have it work with thw 1131 I already have? Basicly do I need two 1240 or one?
Thanks again
Kevin
