1131ap not appearing in 2504 gui
Kin Loo
I have 9 access points of different models connected to my 2504 wlc. Currently, the CAP3502I and three LAP1141N have successfully joined the mobility group. Whereas there are three LAP1131AG and one AP1131AG are not listed in the gui.
I have recently converted these AP from LWAPP firmware to autonomous firmware.
Troubleshooting from the ap perspective, they seem to get valid IP addresses from my dhcp router.
Please let me know if you need any outputs. Thanks!
Jurgens L
Level 3
Level 3
If you run the AP's on autonomous IOS (k9w7) images, then they won't be able to join the WLC, they need to be on k9w8 which is the lightweight AP image.
<<< Please help the community by marking useful posts helpful, or accept as a solution if it resolved your issue >>>
10 Replies 10
Leo Laohoo
Post the complete output to the following commands:
1. WLC: sh sysinfo;
2. WLC: sh time;
3. AP: sh version; and
4. AP: sh ip interface brief
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.2.111.3
Bootloader Version............................... 1.0.16
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 15.0
Build Type....................................... DATA + WPS
System Name...................................... WLC
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.10.1.3
Last Reset....................................... Power on reset
System Up Time................................... 0 days 2 hrs 51 mins 46 secs
System Timezone Location......................... (GMT +9:30) Darwin
Configured Country............................... AU  - Australia
Operating Environment............................ Commercial (0 to 40 C)
--More-- or (q)uit
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +30 C
External Temperature............................. +34 C
Fan Status....................................... 3432 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ D0:C2:82:E0:8F:80
Maximum number of APs supported.................. 10
(Cisco Controller) >show time
Time............................................. Wed Mar 27 22:17:03 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT +9:30) Darwin
NTP Servers
    NTP Polling Interval.........................     3600
     Index     NTP Key Index     NTP Server      NTP Msg Auth Status
AP0017.95b0.c82c# sh ver
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(25d)JA1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 11-Aug-11 02:44 by prod_rel_team
ROM: Bootstrap program is C1130 boot loader
BOOTLDR: C1130 Boot Loader (C1130-BOOT-M) Version 12.3(7)JA1, RELEASE SOFTWARE (fc1)
AP0017.95b0.c82c uptime is 2 hours, 50 minutes
System image file is "flash:/c1130-k9w7-mx.124-25d.JA1/c1130-k9w7-mx.124-25d.JA1"
cisco AIR-AP1131AG-N-K9    (PowerPCElvis) processor (revision A0) with 25590K/7168K bytes of memory.
Processor board ID FHK1018C0CD
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:17:95:B0:C8:2C
Part Number                          : 73-8962-09
PCA Assembly Number                  : 800-24818-08
PCA Revision Number                  : A0
PCB Serial Number                    : FOC10170ZMR
Top Assembly Part Number             : 800-25544-06
Top Assembly Serial Number           : FHK1018C0CD
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1131AG-N-K9
Configuration register is 0xF
Convert these AP in capwap mode.
You are still using Autonomus image.(
AP0017.95b0.c82c#sh ip int bri
BVI1 10.10.1.13 YES DHCP up up
Dot11Radio0 unassigned YES NVRAM administratively down down
Dot11Radio1 unassigned YES NVRAM administratively down down
FastEthernet0 unassigned YES NVRAM up up
Jurgens L
Level 3
Level 3
sounds good for a try, i will try it tomorrow and will mark as solution . .  Thanks
Time and date of the controller is incorrect.
Configure NTP.
the time of my controller is correct, so is the AP. It is the first thing I configure on controller as it does not retain upon reboot.
I have not set up ntp for my network so i would use manual config for now.
