1142 Default mode LAP or Autonomous ?
harish_chopra1
Hi All,
Just have a basic querry, What is the default mode of 1142 AP. When it's shipped from Cisco, Does it works as LAP or it can be used as a Autonomous ?
Also, incase we just get it shipped from Cisco, does it have any default IP address that we can use to telnet it from the PC.
Pls. suggest. Thanks !
Harish
9 Replies 9
nikhilcherian
Level 5
Level 5
The default mode as per your quote to Cisco, you can ask for CAPWAP or IOS  image.CAPWAP mode AP will have default IP of 10.0.0.1, if you haven't configured DHCP.
NikhiL
Hi NIkhil,
That's right that after getting the console we can come to know via ios image version. But what the default status, when Shipped from Cisco ?
Thanks !
George Stefanick
AIR-LAP1142N-A-K9 = CAPWAP part number
AIR-AP1142N-A-K9 = Autonomous part number
Same AP just different code and you can swap code if needed.
Oh  Yes.. That's very basic thing I always ignored to see.
Thanks alot for bringing it to my notice.
If you find any of these post helpful please support the rating system ...
Hi George,
today I get my first AIR-LAP1042N-E-K9. I didn't know about the LAP - AP differences.
But may be it's possible to swap mode to autonomous?
Daniel
Yes, you can convert the Lap to autonomous mode. Check cisco.com for process.
Harish Chopra
Sent from my iPhone
Yes, of course.
here is the doc:
https://supportforums.cisco.com/docs/DOC-15126
If you find this helpful please support the rating system
thanks
Wow.... what a fast answer. Thanks.
But I'm not able to download the file c1140-k9w7-tar.124-25d.JA1.tar, because I have no service contract :-(
