01-12-2005 11:21 AM - edited 07-04-2021 10:20 AM
If I use a 1200 with both A and G radios, can't I only hook one antenna up to each radio? If so doesn't this reduce the effectiveness of both radios due to multi-path interference and not being able to use 2 antennas for diversity?
01-12-2005 01:56 PM
Well, it COULD reduce the effectiveness, if you have multipath interference. It will vary consierably, depending on the environment.
Multipath of a level sufficient to significantly impact performance is not an absolute. That's where a good site survey is especially useful to determine signal quality versus signal strength.
Personally, I like to implement diversity if it's available.
The standard "A" radio / PCcard doesn't really have an option for multiple antennas: It's pretty much "what you get is what you get."
Good Luck
Scott
02-01-2005 04:59 PM
Not sure about the new AP1230, but in the older models the 802.11a upgrade kit/module had a 5GHz antenna attached to the card, which left the two RP-TNC sockets free for diversity 2.4GHz antennas.
