1310 BRIDGE INTERMITENT CONNECTIVITY
edavila
Connecting two LAN´s P2P via repeater Bridges and trasnporting 4 VLAN´s, root´s located at each LAN and 2 non-root at repeater (Hill), I have intermitent IP connectivity even that int dot110 association is never lost and signal strenght is above 75%. This is the config for all radios (except for name and IP)and SSID´s are also different for each pair root/non-root. When this happens I shut/no shut the Dot110 interface or enable spanning-tree for default VLAN (1)at dot110.1 and works for a while.
IOS version 12.3(7)JA1 and 12.3(2) JA
Swithes 1 3560 configured as Trunk spanntree portfast trunk enabled (there a re no loops)
dot11 vlan-name Administration vlan 5
dot11 vlan-name BVT-Datos vlan 2
dot11 vlan-name Sempra-Datos vlan 3
dot11 vlan-name Techint-Datos vlan 1
dot11 vlan-name VOIP vlan 4
dot11 ssid Administration-Techint-Bridge-01
vlan 1
authentication open
infrastructure-ssid
dot11 ssid Administration-Techint-Bridge-12
vlan 2
dot11 ssid Administration-Techint-Bridge-13
vlan 3
dot11 ssid Administration-Techint-Bridge-14
vlan 4
dot11 network-map
bridge irb
interface Dot11Radio0
no ip address
ip helper-address 10.90.25.253
no ip route-cache
encryption vlan 1 key 1 size 40bit 7 8D345E5120DE transmit-key
encryption vlan 1 mode wep optional
speed basic-1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
rts threshold 2312
cca 75
no cdp enable
infrastructure-client
interface Dot11Radio0.1
encapsulation dot1Q 1 native
ip helper-address 10.90.29.253
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
bridge-group 4 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.2
no ip route-cache
bridge-group 2
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface FastEthernet0.4
no ip route-cache
bridge-group 4
interface BVI1
ip address 10.90.25.241 255.255.255.0
no ip route-cache
ip default-gateway 10.90.25.253
bridge 1 protocol ieee
bridge 1 route ip
bridge 2 protocol ieee
bridge 3 protocol ieee
bridge 4 protocol ieee
kka
Level 5
Level 5
IIRC "portfast" isn't active on ports in trunking mode.
For a pure bridge configuration (i.e. root/non-root)
only one (infrastructure) SSID is used. Try removing
the "Administration-Techint-Bridge-12/13/14 SSIDs"
from your config.
We had some spanning tree problems in 12.2 when
using a native VLAN not 1. This was fixed somewhere
in 12.3 and by disabling STP on all bridge groups,
except bridge group 1. (no bridge N protocol ieee)
Personally I'd rather use 12.3(4)JA1 for bridging
of trunks. Our initial tests with with 12.3(7)JA1
showed instabalities even for short distances.
