02-05-2009 08:44 PM - edited 07-03-2021 05:07 PM
Hi There,
I have 4404 WLC running 5.2,I have connected this WLC to a switch using LAG.My AP and WLC are on seprate segment.For illustration i can say Controller is on 192.168.50 and all my ap are on 142.240.83.0,Now 35 of my ap's connect to controller(i am sending dhcp option 43),but 6 of my ap's do not connect but if change the segment for these 6 ap to 142.240.82.0 than they also connect to same contoller without an issue.I am clueless why it is happening
02-11-2009 02:26 PM
Maybe the trunk port are prunning what VLAN is/are allowed.
02-11-2009 02:35 PM
The APs shouldn't be connected to trunk ports though. If they are, that may indeed be the problem though.
Are your APs getting DHCP addresses? You can tell by consoling into them once they've booted.
