1600/ 2600 with single external antenna
gmckay2e2
I have an unusual request to support an access point with a single external antenna to cover a small physical area (elevator car!!). All Cisco's currently shipping APs have dual band antennas using MIMO for throughput in "normal" deployments. Will a deployment with a single antenna work?
Scott Fella
You would have to disable the non used antenna ports and only enable one port. Your better off using a 1602i or a 2602i.
-Scott
Martin Bosch
What about using an access point with an internal antenna?
like the AIR-CAP1602I-x-K9 /  AIR-CAP2602I-x-K9
or do you already have the access point with a external. Otherwise what about something like
Dual-Band Omnidirectional
AIR-ANT2544V4M-R=
AIR-ANT2524V4C-R=.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
