cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
1850 AP Mobility Express and ACLs - Quick Question
farshidkhodaei
I will be deploying a Cisco 1850 with Mobility Express and had a question:
Is it possible to lock down the guest WLAN/SSID just to a few specific websites? I know you can create ACLs, but I am not sure if you can use those ACLs to only allow access to a few websites? If it's not possible to do this via the ACL, is it possible to accomplish it using any other method on the access point? Thanks!!
0 RESPUESTAS 0
