07-05-2016 02:33 PM - edited 07-05-2021 05:22 AM
Dears,
I have 4 to 6 Autonomous APs running in each location (around 65 locations). All APs are configured to select the least congested channel. There many other APs running around our locations which are using the standard non overlapping channels. So our APs end up with some non standard overlapping channels. As shown in the attachment. We are using some game card readers. In a busy day the readers are running very slow.
These readers work only in 2.4 Ghz. Can anybody suggest an optimum solution?
07-05-2016 03:36 PM
Statically assign CH1,6 and 11 for your APs
Rasika
07-05-2016 06:14 PM
Channel selection depends on the frequencies that are permitted for a particular region. For example, the North American and ETSI 2.4 GHz band permits allocation of three non-overlapping channels (1, 6, and 11), while the 5 GHz band permits 23 channels.
The channels should be allocated to the coverage cells as follows:
