11-21-2013 04:43 AM - edited 07-04-2021 01:18 AM
I know the following sound weird, but i've been asked to do so...
I have 1 AP 1602i that need to have 2 SSID's on the same radio (dot11radio0) untagged. So that client from both WLAN's gets ip addresses in the same range..
I can do it with vlans, no problem. But how to do so, without vlans?
11-21-2013 04:47 AM
HI Steen,
You need to configure 2 ssid on one subnet, then follow these 2 docs.
https://supportforums.cisco.com/thread/2206380
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configuration/guide/s43ssid.html
Hope it Helps.
Dont forget to rate helpful posts
11-21-2013 11:03 AM
Hi Steen,
See whether below helps, I have connected AP to G1/0/10 interface of a switch where DHCP defined for users. Only one SSID is broadcast & otherone is not broadcast SSID (but clients can connect).
SW Configuration
interface Vlan1
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool VLAN1
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
interface GigabitEthernet1/0/10
end
AP configuration
hostname AAP
dot11 ssid ABC
authentication open
authentication key-management wpa version 2
wpa-psk ascii Cisco123
dot11 ssid DEF
authentication open
guest-mode
interface Dot11Radio0
encryption mode ciphers aes-ccm
ssid ABC
ssid DEF
station-role root
bridge-group 1
interface Dot11Radio1
ssid ABC
ssid DEF
station-role root
bridge-group 1
interface FastEthernet0
bridge-group 1
interface BVI1
ip address dhcp
Here is the client assoication verification
AAP#show dot11 associations
802.11 Client Stations on Dot11Radio1:
SSID [ABC] :
MAC Address IP address Device Name Parent State
0022.fa94.6858 192.168.1.12 ccx-client AAP self Assoc
802.11 Client Stations on Dot11Radio0:
SSID [DEF] :
04f7.e4ea.5b66 192.168.1.13 unknown - self Assoc
Rasika
**** Pls rate all useful responses ****
