21 mask network on wireless
stevechapman_2
Beginner
Beginner
I currently have 4 controllers with multiple vlans configure for one ssid.  The vlans are group by building and each vlan is a /24 network.   I have been asked to create one vlan per controller with a /21 network.  I am worried about the size of this network and impact it will have on my wireless users.   Do I have an issue with possible packet collision in wireless?  Also I currently don’t allow wireless users, via the check box on the controller, to talk to each other will this stop the broadcast issues with such a large network?
BRYN JONES
Beginner
Beginner
Hi Steve
I do know that there is a University in the USA using /21 on their wireless:
950 APs
Peaks of 1000-1300 concurrent users
/21 network is assigned
About 50-60 packets per second of Broadcast
jilahbg
Beginner
Beginner
We are talking about different kind of broadcasts/collission:
RF: Each AP talks at a certain channel to all associated clients. Only one can talk at the same time. Thats why it´s not a good idea to have too many clients per AP.
IP: An IP-network is a IP broadcast-domain. That means that clients that sends broadcasts (l2 or l3) talks to all other devices within the same broadcast-domain. However, when talking about Cisco WLC-solution the IP-network size is irrellevant as long as the wlc is configured the right way. You can configure the system to not allow client to client-traffic as well as not allowing broadcasts. That´s why you can have thousands of clients in the same IP-network when using Ciscos leightweight wireless solution.
Br Jimmy
I currently have the peer to peer blocking set to drop so this stops client to client right?  Does this block the broadcast or is there something else I need to configure like broadcast forwarding?
Note:  I am running version 6.0.182.0 layer 3 mode.
thanks for your help
Steve Chapman
LAN Engineer
Recognize Your Peers
