02-03-2013 09:43 PM - edited 07-03-2021 11:28 PM
Cisco best practices states that no more then 25 associations per AP, otherwise wireless bandwidth issues would occur.
Is it 25 associations "PER AP" or is it "PER BAND e.g 2.4Ghz and 5.0Ghz" which equals to 50 associations (25 on 2.4Ghz and 25 on 5.0Ghz) if you have a Dual band AP.
Solved! Go to Solution.
02-04-2013 03:51 PM
CSMA-CA which 802.11 uses, is based around a physical
02-04-2013 12:57 AM
Per AP.
02-04-2013 07:04 AM
Actually this is a loaded question and a time to share some education
You have 2 potential issues that can cause bandwidth degrade.
1. If you had 25 on 2.4 and 25 on 5ghz, each channel would support its own Csma/ca. So really you could get 50 clients on the 2 channels with little wireless degrade.
2. The issue becomes when the traffic is merged onto the wired side of the ap. if you had 50 clients pumping heavy traffic you will see degrade.
Just my two penny's
02-04-2013 03:11 PM
Thanks George,
So basically wireless collisions would be segmented to their own band 2.4Ghz and 5.0Ghz, in the sense that the 50 clients (25 on 2.4Ghz and 25 on 5Ghz) would be just web browsing and the AP has a gigabit connection back to the switch, I should see no bandwidth issues correct?
Also is the wireless bandwidth cut up in relation to the band? e.g 25 clients on 2.4Ghz = 54mb/25 = ~2mb per user
and if you have only 1 client on 5.0Ghz do they get the full bandwidth? On the same AP.
02-04-2013 03:51 PM
02-04-2013 09:08 PM
Awesome, thanks for all the help =)
02-04-2013 09:15 PM
No worries. Thanks for supporting the rating system !
