3650 WLC, switch3560, TWO AP -problem is joind secend
tomasznowak2
Good Moring,
i have a problem with wlc 3650
My problem is AP2(second) is not Join to :
WLC *Mar 2 15:16:49.180: *%CAPWAP-3-PHY_PORT_ERR2:Switch 1 R0/0: wcm: Cannot process capwap packet from AP e00e.dabc.16f0, since there is another AP (e00e.dac1.ff20) already join with same physical port.
but AP1(first) is connect and ok..
SW1<->SW2
switch access vlan 100
switch mode access
SW2 to AP 1 & AP2
switch mode access
where is problem?
Sandeep Choudhary
As far as i know, you must connect both AP in 3650 switch diretly else it will not work.
Dont forget to rate helpful posts
Sandeep Choudhary
Why ? soft limit?
its a requirement from cisco side:
chekc point 1 on this post:
https://mrncciew.com/2013/09/29/getting-started-with-3850/
Dont forgte to rate helpful posts
