04-07-2017 05:46 PM - edited 07-05-2021 06:49 AM
I am needing to mount some 3802e's on the wall and would like to use the AIR-ANT2566P4W-R. I want to use the AP in a dual 5GHz mode. With this antenna connected, does it serve both 5GHz radios or do I need to connect another antenna to the primary 4 ports on the AP in addition to the smart antenna connector.
The other option is to just wall mount the 3802i but I know it says that should be avoided unless roaming is not an issue, example: hotspot, kiosk, or very small venue areas where large uniform coverage is not needed.
I am deploying these AP's in a 400 seat auditorium/lecture hall.
Thanks for the help.
Solved! Go to Solution.
04-07-2017 07:18 PM
So this is how our SE describes the 3802E:
1. You use the standard antenna, like the AIR-ANT2566P4W, and this will broadcast in 2.4 Ghz & 5.0 Ghz.
2. In order to use the second 5.0 Ghz then you'll need to get the breakout cable and connect another set of 5.0 Ghz antennas (4 x RP-TNC) to the breakout cable.
04-07-2017 07:18 PM
04-08-2017 09:07 AM
Leo is right. Take a look at the link for the "smart antenna"
http://www.cisco.com/c/en/us/td/docs/wireless/controller/technotes/8-3/b_cisco_aironet_series_2800_3800_access_point_deployment_guide/b_cisco_aironet_series_2800_3800_access_point_deployment_guide_chapter_01.html#id_24841
-Scott
