02-16-2018 11:33 AM - edited 07-05-2021 08:15 AM
I'm trying to configure these new 3802s we got but when I plug them in, all I keep getting is "waiting for uplink IP address and reachable default gateway"
When i do capwap ap ip address and type the ip, subnet and default gateway or just IP and subnet I get "Error: invalid ip/netmask/gateway config." nothing takes.
Any suggestions? the current VLAN doesn't assign IPs via DHCP and that's how we have all other APs (again these 3802s are new to us)
AP Running Image : 8.2.151.0
02-16-2018 01:39 PM
I think you just got an Bug:
02-16-2018 02:00 PM
01-09-2020 04:12 AM
I do have DHCP option 43 enabled. Looks like 50 reloads didn't help. If DHCP option 43 was disabled, would it be any help?
01-09-2020 01:11 PM
Disabling DHCP option 43 would only make things worst.
01-13-2020 05:23 AM
Hard to imagine for me how it can be worse than it is when WAP is not usable. But still wonder why you mentioned option 43 in your first comment.
01-13-2020 03:14 PM
Cisco APs use DHCP Option 43 to find their WLC.
Without DHCP Option 43, one must console into each AP and "instruct" the AP which WLC to go to.
01-13-2020 11:59 PM
You should consider opening a TAC Case with Cisco.
I had the same issue with a couple of 3802is and it ended up being a bug that was rectified by hardware upgrade.
https://www.cisco.com/c/en/us/support/docs/field-notices/701/fn70143.html
Let me know if this helps.
02-17-2018 03:49 AM
I've just run in to the same issue. Same model AP, same firmware version. Consistant accross 4 seperate batches of APs (running multiple projects at a large International Airport. Not happy!
Have tried rebooting a number of times and can't get any of them to work. Other models and/or versions of code are working fine.
-Brett
02-17-2018 08:39 AM
02-17-2018 02:16 PM
02-19-2018 05:27 AM - edited 02-19-2018 05:34 AM
Ok so I put it on another wireless VLAN that does get DHCP, gets an IP and everything but then when it gets stuck at this:
[*09/15/2017 00:23:14.5772] CAPWAP State: Discovery
[*09/15/2017 00:23:14.5811] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*09/15/2017 00:23:24.0798] CAPWAP State: Discovery
[*09/15/2017 00:23:24.0914] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
When I try to configure the controller IP it doesn't take the old way as by doing capwap ap controller ip address 10.0.14.81 like the other APs I configured so I looked and seems like you're supposed to use Capwap ap primary-base ip address 10.0.14.81 but when I do that, I get this:
% Invalid input detected at '^' marker.
#Capwap ap primary-base ip address 10.0.14.81
^ (meaning it doesn't like the IP address)
When I type ? for help it says WORD
Then I tried capwap ap primary-base 10.0.14.81 and tells me incomplete command. It's so frustrating lol
The controller's Software version is 7.0.240.0
Is there a way to enable the web interface on these things? the method I read online doesn't even exist on this
02-19-2018 11:19 AM
Hold on, this won't work. 2800/3800 require the controller to be running, at least, 8.0.152.0.
02-19-2018 11:59 AM
GAH! well that makes things a little more difficult... Thanks for the input! I'll see what I need to do now.
02-19-2018 10:24 PM
