you can specify controller ip address:
capwap ap controller ip address <ip>
as per logs ap is getting wlcs ips 10.23.50.4 and 10.23.50.5
silly question
have u checked license in wlc's ..
They are licensed to 1500
When a 5520/8540 comes out fresh from the factory, it has "0" AP license.
You'll need to activate the license (CLI is better) using the "license" command.
Hello @tdennehy
If you look at MONITOR tab > Statistics > AP Join . Is there any log there? if does, what did this say?
-If I helped you somehow, please, rate it as useful.-
Do you have an active license ? Please check in:
MANAGEMENT > Software Activation > License.
If the status is Inactive, activate it.
Also, double check if time is ok.
In SECURITY > AP Policy make sure "Accept Manufactured Installed Certificate (MIC)" is checked.
Please, informe the AP Part number and the command "show country supported" from the WLC.
