08-20-2014 09:30 PM - edited 07-05-2021 01:24 AM
Hi everyone,
I know from the 3850 online datasheet it does not mention 3700 APs among its compatible devices but someone is insisting (based in field experience) that they are actually 100% compatible.
Is this possible?
Thanks.
08-20-2014 10:05 PM
Yes. It is compatible as long as the AP is directly-connected to the switch.
08-20-2014 10:20 PM
Hi Raul.
They are compatible with 3850 WLC.
But make sure that you must have 3.3.1SE or hogher software version on controller to support 3700 series AP.
From here you can download the latest SW:
http://software.cisco.com/download/release.html?mdfid=284455380&softwareid=282046477&release=3.2.2SE&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Here is the compatibility matrix:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Reagrds
Dont forget to rate helpful posts
08-20-2014 10:20 PM
Very helpfull aswer .. I have a question is the cisco AIR-SAP1602I-E-K9 compatible with the 3850-48P
because I keep getting this error log. Can any one kindly provide any input or useful links.
LOGS FROM CONTROLLER(SWITCH 3850).
WLC_3850>sh cdp ne det
Device ID: AP24e9.b3ec.9234
Entry address(es):
IP address: 10.0.60.121
Platform: cisco AIR-SAP1602I-E-K9, Capabilities: Router Trans-Bridge
Interface: GigabitEthernet1/0/37, Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 176 sec
Version :
Cisco IOS Software, C1600 Software (AP1G2-RCVK9W8-M), Version 15.2(4)JB5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 01-May-14 21:11 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 13.000 Watts
Power request id: 46379, Power management id: 2
Power request levels are:13000 0 0 0 0
Management address(es):
*Aug 20 10:40:43.259: *spamApTask1: 1 wcm: %CAPWAP-3-DISC_UNSUPPORTED_AP: Rejecting discovery request from unsupported AP 24e9.b3ec.9230
WLC_3850>
WLC_3850>
WLC_3850>
WLC_3850>
*Aug 20 10:41:03.259: *spamApTask1: 1 wcm: %CAPWAP-3-DISC_UNSUPPORTED_AP: Rejecting discovery request from unsupported AP 24e9.b3ec.9230 [...It occurred 2 tim/sec!.]
08-20-2014 10:46 PM
I have looked at data sheet for 3850. It does not mention compatible AP's any where. Where can I find this info.
Regards to all.
Sal
08-20-2014 11:50 PM
Yes Its comaptible. but you should have atleast 3.2.0SE software verion on 3850 WLC.
Check this matrix again: http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
which softare version you are runing o WLC ??
is AP directly connected to 3850 WLC ?
paste the output of this from WLC:
sh ver | be SW
show wireless country configured
From AP:
sh verion
