4402 WLC Guest Wireless Setup
mis.vanir
I am trying to setup a Wireless Network on my WLC that is totaly independent of our internal LAN. Port1 is designated at the .14.0 network and Port2 is the .18.0 network. The 14 network (Port1) will be the guest and 18 network (Port2) the internal wireless.
The issue i am having is nothing is routing to Port1. I have the Guest Wireless set to get DHCP from the WLC and i can get an address but i cant get internet access. I tried configuring a Network Route but it will only let me set the service port as the Gateway and not the IP for Port1.
I am running software version 5.1.151.0 and using this guide as it is the only one i can find.
http://www.cisco.com/en/US/docs/wireless/technology/guest_access/technical/reference/4.1/GAccess_41.html
Here is a screen shot of my Interface config.
Any idea as to whats going on or am i way off on how i am assuming these things work. If more info is need let me know.
is the Sonice wall a 10/100 or 10/100/1000 port?  The WLC is 1000 only
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
7 Replies 7
Stephen Rodriguez
The WLC doesn't route.  Network routes are a way for you to force traffic out of the service port.
You need some device that can route/nat on the .14.x subnet
HTH,
Steve
HTH,
Steve
Whats the point of having 2 ports if you cant chose which port to send trafic thru?
you can send the traffic out of the port, but the WLC doesn't 'route' or nat.
What is upstream from the WLC on that port?
HTH,
Steve
HTH,
Steve
Port 1 goes directly into our Sonicwall Firewall and Port 2 goes into our Core Switch.
HTH,
Steve
HTH,
Steve
Sonicwall is 10/100/1000 but i had a 10/100 switch between them. I plugged the WLC Port 1 directly into the Sonicwall now and it is reading 1000 Mbps full-duplex. I will test it to see if this made a different but i was getting a Green Link on the WLC before and the GBIC in Port1 is 10/100/1000 RJ45.
That was it! Stupid thing showed a link light so i assumed it was working! Thanks!!
