4404 wlc is failing to set ip address Wired connection
meliand93
I was able to setup and get my WLC setup, but then it fails to put a ip address on it. The port shows activity, but does not have any clients show up on the server. Any idea's?
Sandeep Choudhary
if i understand you correctly!!!!!
you setup the WLC but cant set the WLC managemnent ip on it?
paste the outout of the these commands
from WLC: sh interface detail management
from swicth: sh run int po <int - where wlc is connected>
Dont forget to rate helpful posts
Interface Name................................... management
MAC Address...................................... 00:21:d8:1e:d4:20
IP Address....................................... 10.10.80.3
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 10.10.80.1
External NAT IP State............................ Disabled
External NAT IP Address.......................... 0.0.0.0
VLAN............................................. 10
Quarantine-vlan.................................. 0
Active Physical Port............................. 1
Primary Physical Port............................ 1
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.10.80.5
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
L2 Multicast..................................... Disabled
Leo Laohoo
Post the complete output to the following WLC commands:
1. sh interface summary; and
2. sh ap summary
an ip config showed
