返信
541N AP question - should be simple
Brett Walters
Why is WPA2 not an option on my devices currently?  They are running firmware 2.0.2 (I know 2.0.4 is out - but I thought the 541N was WPA2 capable out of the box when they shipped).  I see the normal WEP, WPA-Personal and WPA-Enterprise, but not WPA2.  I am sure it is something simple and I am simply missing it - but any pointers would be appreciated.
1 件の受理された解決策
受理された解決策
wjenkins
I don't have a 541N on hand to look at but the data sheet does indicate that it supports WPA-2 Personal (PSK) and WPA-2 Enterprise.
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10492/data_sheet_c78-566239.html
It looks like you can select the WPA version and cipher suite per the administration guide after you select personal or enterprise.
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/AP541N/administration/guide/AP541Nadmin.pdf
I would recommend using either WPA-TKIP or WPA2-AES and not to mix the versions.
元の投稿で解決策を見る
2件の返信2
wjenkins
See?  Duh, it was an easy one.   You are correct!
