5508 wireless controller - and limit SSID's
Martin Bosch
I am trying to figure out if I can limit some of my access points to only some SSIDs available – instead of everything that’s available on the controller?
Scott Fella
Here is a support doc that e plains ap groups. This way you create ap groups that has specific ssids and what interface the SSID is tied to and then you add APs to that ap group.
https://supportforums.cisco.com/docs/DOC-19033
-Scott
5 Replies 5
Scott Fella
Yes... You need to look at using AP groups.
-Scott
Scott Fella
-Scott
Thanks man... - Yet again ;o)
You might find this helpful
http://www.my80211.com/cisco-wlc-labs/2009/3/22/cisco-ap-group-nugget.html
I blogged about this and did a video to help
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
manjeets
Level 3
Level 3
Hello
Hope you are doing good,
I am sending you a link related to your query, This way you create ap groups that has specific ssids and what interface the SSID is tied to and then you add APs to that ap group.
It will resolve your query.
