09-16-2014 06:31 PM - edited 07-05-2021 01:32 AM
all 10 of my ap's registered for a few days then I reboot 2 switches and
5 of my ap's got ip address from another dhcp pool not mine?
09-16-2014 09:07 PM
Check the switch port config. It must be assigned to different vlan.
Correct it and try again.
Dont forget to rate helpful posts
09-19-2014 06:22 PM
check the switch config
09-22-2014 11:00 PM
Hi ,
You might also need to check if these APs were in Flexconnect mode. If yes, please check the native VLAN on the uplink switchport. There are chances (as others mentioned) that the switchport config has changed after a reboot.
HTH,
Tony
