isdollsm1
Beginner
5508 WLC USB slot
I am trying to use the USB0 and USB1 in a 5508 WLC. I have formatted my flash drive for FAT and FAT32 without success. I want to transfer some files over, is this possible using the USB ports in the front of the controller?
1 ACCEPTED SOLUTION
it was hw option included on the original chassis design, but it was never activated on the software side
(no feature implemented)
regards
3 REPLIES 3
Javier Contreras
hi
not supported
regards
Thanks for your reply. Is there any Cisco documentation on this? I have looked but very limited info. Also if not supported what are those USB ports used for?
regards
Create
Recognize Your Peers
Content for Community-Ad
