5520 8.5.140 and tacacs+
craigshawm6
We have the IP addresses of our ISE (tacacs) servers correct, the key is correct, the wlc is listed in the tacacs network devices, but we cannot get the management users to authenticate against the tacacs. Only users in the local database can remote into the 5520.
Jonas Kalldert
Have you added and placed Tacacs+  correctly in  "Security - Priority Order - Management User" ?
regards,
Jonas
**Don't forget to rate helpful posts**
Jonas Kalldert
regards,
Jonas
No I did not. I overlooked that. Fixing that now. Thanks!
